Canon LTM 50mm 1.4 lens.
leica M2 fan
11:08 PM
NorCal
Have been using this lens for about a week now and find it easy to use but I have found that the infinity lock bothers me somewhat. Is there a purpose for this lock other than the obvious? Can it be disengaged and is that advisable? TIA for any input.
You can take it off by unscrewing the knob.
But I leave it on because it gives the lens additional stability.
Roland.
I've just found myself leaving the lens focussed at about 10-15 feet. Quick to change closer or to infinity if needed.
I've also found that for LTM bodies, it's easier to remove the lens if it's locked at infinity. Dunno why. But it is.
Thanks Guys
Thanks Guys
I knew if I put the question out to you guys I'd have an answer very soon and I did. Thanks to all. I guess I will leave it on. Thanks again.🙂
