Davidhel
Hi all
I have a problem with a Canon P : (
Canon rangefinders are relatively new to me, but I have restored several LTM Leica's over the last few years....
This one came to me in a sorry state. I opened it up, cleaned and lubricated... it was all going so well. I reassembled.. and here's my problem. When I reattached the self timer arm it wasn't quite at vertical (more like 11 o'clock) - I should have taken greater care to put it on correctly and tighten it up first. Instead, because it was slightly angled when I tightened everything back up, when I set it, it won't release with the shutter... My thinking is that I've 'over wound the self time mechanism' through the wrong alignment - see pic.. :bang:
Canon p, self timer mechanism by David Helmore, on Flickr
How to fix is the big question. Everything locks. If you raise 'the arm' slightly on the self timer mechanism the shutter fires perfectly... so I'm thinking I will need to remove the slow speed mechanism and try to fix before reattaching to the camera?
Is this something any of you have had to fix before?... if so, I would appreciate any tips you can give : )
Thanks in advance
Dave
Canon p, self timer mechanism by David Helmore, on FlickrHow to fix is the big question. Everything locks. If you raise 'the arm' slightly on the self timer mechanism the shutter fires perfectly... so I'm thinking I will need to remove the slow speed mechanism and try to fix before reattaching to the camera?
Thanks in advance
Dave
