Canon sqeal: details
lorriman
11:28 PM
Does anyone know how long it generally took for the Canon squeal to manifest?
And when did Canon change the type of lube/grease to stop this problem? From somewhere I can't recall I've been lead to understand that with the right lube/grease the problem shouldn't come back: but I might be wrong about that.
Thanks, Petronius.
Do those instructions make it relatively easy for non-engineer to fix an A-1, which is the camera I wish to fix? I don't know german, so I thought to ask before I tackle the translation problem.
Ok, thanks for that.
Do you have a fair bit of experience fiddling with cameras? I have none, so I may need to weigh up the chances.
