Canonet GIII QL 17 in the mail
L
lkgroup
Guest
I have a Canonet GIII QL 17 coming in the mail, it should arrive anyday. I was wondering about your experiences with what type of batteries to use. I know that the orginal recommened battery is no long made and it was 1.3v and ones that fit are 1.5v. I have read that these are usable but I have read that the ASA needs to be adjusted, but others have said this is only a legend.
What do the users of this camera recommend for a Battery replacement?
Thanks
Leo
For print film, you should be Okay with 1.5v Alkaline batteries. Hearing aid batteries give the correct voltage, and are cheap. They have a short life once used; they produce electricity after being exposed to air.
If you go the Alkaline route, or find a Mercury Cell, you can extend its life by turning the Canonet to manual mode when not in use. That turns the meter off; zero drain on the battery. It will not extend the zinc-air battery, its clock starts ticking when you break the airtight seals.
