Canonet & how to get to the shutter blades...
Spyderman
6:57 PM
Bratislava, Slovakia
I'm just wondering whether it is difficult to get to Canonet 17 GIII's shutter. I already had the lens apart, but only enough to clean the shutter blades with Q-tips and naphta. (just removed the rear and front group as in H.Taber's article)
I would like to clean it thoroughly, get rid of all the sticky thing, maybe put some watch oil inside the clockwork...
So, does anyone have any tips how to get in there and get back safe? 🙄
The shutter slow timer mech like most is designed to run "dry". If you put any oil on it, it is likely alter the speeds at best and probably gum it up.
Kim
Spyderman said:
Thanks, I'll give it a try. I'm afraid that there is a pre-existing dent in the front of the barrel at the filter threads, and I suspect that is adding extra pressure to the retainer as well. It's not pretty.
Best regards,
John
