zimster
The camera arrived today. I bought a 675 hearing aid battery and an "o" ring at Napa Auto Parts in anticipation of the camera's arrival.
I downloaded the manual and now that I have the camera in front of me I can see a major difference in the battery compartments.
My QL 17 has a hole 1" deep very unlike the QIII which is a slide out pocket.
How does this tiny battery fit into such a hole. Do I get a bigger "o" ring and use aluminum foil to hold it in place?
And when I remove the tab, which side touches the contact? The tab has 2 + signs on it. There is a diagram inside the cover but it looks as though this battery should touch the cover which means it would be about 1/2" diameter and 1" long!!
By the way this camera has a 1.7 45mm lens.
Where do I get a manual for a QL17 and not a QIII?
PS I have no idea how to use this camera and I would just as soon go manual and forget batteries altogether if I knew what to do!!
Thanks
Zimster
Thanks
Zimster
