Caps, hood, and Filters for DR 'cron?
wjlapier
5:07 AM
Can someone tell me the correct Leica hood for the DR 'cron? Date important?--'58. Filter size is 39mm--right? What size push on cap would I need? Finally, any aftermarket seller who's caps and hood you like better--prefer original, but if too expensive I'd use aftermarket.
Thanx--
The "correct" hood is the IROAA.
But you might prefer the more modern 12585 or variants thereof. These hoods can be reversed and have a special slotted cap, when reversed.
The lens is E39. The cap's inside diameter is 42mm or so (there is a felt ring on the originals).
You can buy cheap 39mm or 42mm non-Leica lens caps, even with a Leica logo on them 🙂
Heavystar sells both vented and non-vented hoods that you can use. There is a small W-39mm hood that I like particularly.
Roland.
LEICA Chrome circular metal lens hood #12550 (meant for the 50mm Elmar-M)
