Carbon Fiber Tripod?
JoshRoot
The NW will rise again.
12:35 AM
Pacific Northwest
Any suggestions for a carbon fiber tripod that won't break the bank? I'd like it for some RF photos and to use when packing my 360VR kit through the woods.
I read a post somewhere that mentioned Gitzo copies on ebay, I think they were called Feisol. Anyone seen one of those in real life?
I think there are some ones made by Dynatran, or something like that, on ebay. I think NL2377 bought one recently, you might ask him how he likes it. I know they can go for under $100...
You might want to look at the Bogen/manfrotto DIGI series. I have had one for about 3 years and love it. It is tall enough, sturdy enough for an SLR kit but weighs about 3.5lbs.
I think the 724 model is most similar to mine. It also has a handy rucksack to carry it in included. You can get a ball head or 3 way head built in all for about $100. They are not
carbon but cost a whole lot less. I have hiked long distances with mine in the rucksack and it does not bother me.
I use a very small Gitzo carbon fiber tripod and within its limitations I am very pleased with it. It is very small and light, well constructed and a good leg lock system. It is outfitted with a similarly lightweight Gitzo ball head and as a system works very well. One nice feature is the ability to extend the legs into a wider than normal stance. This adds to the stability when doing close ground work. It's no Sachtler by any means, but then it doesn't weigh thirty pounds either 🙂. I'm glad it's in the arsenal -- although I'll often use a mono-pod instead of this little tripod.
I just got myself a $300 Manfrotto, and thus far I'm quite pleased with it. Of course, I've only taken it out once, but that once was up a mountain 😉
I'll give it a much more thorough testing out next week when I head out to the Smokies with the Manfrotto, a Leica m7, and an Ebony 4x5. 😀
Of course, if that's beyond your budget, just ignore this part.
Quite a few people have recommended the Giottos carbon fiber 'pods, which are definitely on the inexpensive side compared to the likes of Manfrotto and Gitzo (well, pretty much anything but Linhof is inexpensive compared to Gitzo, but that's besides the point).
Velbon's Carmagne series is also available at a good price. They use a bit of magnesium so they are a tad heavier but still very light.
allan
I bought a Velbon Carmagne 540 last week, not so much for 35mm rangefinders, but for those times I want to put my 4x5 on a tripod in the field. For that purpose, it is well suited, particularly if you're carrying a tripod and a big camera any distance at all.
The head doesn't have quick release but rather a knob with a tightener/loosener lever. It's not a problem for me but some folks might consider it one. Also, the feet are not spiked. Again, not an issue for me, but a goodly number of folks like to plant their tripod on turf or soil for the extra rigidity.
With a 35mm RF, I'd definitely hang a bag over it to give it some weight. It's stiff and rigid but I could see a gust of wind moving it around.
I also have a Bogen from the 3000 series with a 3030 head whose weight sent me looking at CF. With the Carmagne, I don't see myself using the Bogen outside very much any more.
I use a Giottos MT 8180 carbon and am well pleased it is under 300 from Philly photo, on E**y . It is light plenty tall 6' without center column and will fold to more positions than a contortionist. Of course I shoot a lot of macro. I use it without the center column with the 4x5 Tachihara and am quite pleased
The Dynatran Tripods are great! I have 3 of them, a heavy weight i use in my studio, and a Carbon fiber i use in the field as well as the Carbon fibre monopod. All exceptionally strong and stable.
At what point does the bank break? I have two Gitzo carbon fiber models, 1127 and a 13XX ( don't remember the specific model). I paid $409 for the 11XX this summer from Camerawest and added a magic ball head. I purchased the 13XX a few years ago from a dealer on evilbay and think I paid about $475. They're very light and extremely durable.
If this isn't in the budget look at a used Tiltall made by Leitz. I still have four of them and used them for twenty plus years with my 35mm and MF equipment. A very clean used one will run fifty or so dollars.
http://www.photo.net/photodb/member-photos?user_id=790229
Get yourself a used Gitzo Josh and you won't ever have to buy another one. They run around 50% of the new price. Get new bushings for it, clean it up & spray with silicone and you'll have a new tripod. They are the best, no question.
I bought the Giottos MT 8180 carbon but have had many problems with it. Maybe it's the heat and humidity over here in SE Asia but the legs bind together and I end up unscrewing the whole leg section (sometimes all three of them) and one of the feet "fell off" it was badly glued. I should have gone for the Gitzo CF
so i'd agree with Peter above.
Spikes ?
Spikes ?
Jason Sprenger said:
Velbon Carmagne 540
The rubber feet should screw up to expose the spikes 🙂
Unless the Stateside model is to a different design - as well as name - but check the Velbon Sherpa Pro CF-540 or here ....
rdgs
