Chiyoko (or Chiyoda Kogaku, later Minolta) made 2 versions of this lens. The first has a 40.5mm filter ring and stops down to f16, and the second has a 43mm ring and stops down to f22. The 2 versions appear optically the same, based on weight, sizes of the elements, and the images they produce. I do not know why they changed filter size, but perhaps it was to match the filter size on the Super Rokkor 50/2 for the Minolta Super A (same glass). There are Minolta-made screw-in and clamp-on hoods that fit these lenses.
This lens' reputation is basically absent, probably because there were not very many made and it is not found very often today. That won't stop me from rendering my opinion, however, that the Super Rokkor 50/2 is an outstanding lens overall -- plenty sharp and contrasty as you have noted -- and as good as any f1.8-2 lens of the era. I have not encountered any flare problems, although I always use a hood and have not purposely "challenged" the lens in flare-prone situations. The later Super Rokkor 50/1.8 (in LTM and Super A mount) is even better, but harder to find.
David
