cleaning oil on aperture blades CZJ
FrankS
Registered User
10:27 AM
Canada, eh.
Haven't gotten any help yet on cleaning haze in a Summar lens, apart from Joe's gerous offer of his expertise, so how about cleaning some oil on the aperture blades of a CZJ 50mm f2 lens? Can it be done easily, or is this a tough one?
maybe bump that other post up frank. i probably just got lost.
despite my last dreadful attempt at cleaning...i did a few of the canon lenses and they were pretty easy/simple.
even the summicron came apart easy. i would have been better off sending it off right away, when i found out that the haze was not accessible w/o better tools/knowledge etc.
wait for someone with some pics or well described explanation and then give it a try.
just leave the canned air in another room😉
joe
I've always wondered about this - who cares if a RF lens has slightly oily blades? It's not like it has a stop-down diaphragm or anything.
Of course, oil could migrate to the inner elements, so... is that the reason you'd clean them?
The rear module should come off easily enough.
This is for the Contax? Oil will not seep from the (nonexistent) helical. Is it heavy? On one J-3, i've seen it seep from the helical into the mechanism. But the Nikon's and Zeiss-Opton's are pretty well behaved.
The "cheeze-wiz" way I did it was to just sop it up from the back with the rear module removed. Open and close the aperture a couple of times. Hit it with a little Ronsonol to help it along. Sopped it up with lintless lens cleaning tissue. Not the best way by anymeans, just quick and dirty. Got "most of it" out.
Stu W said:
The oil can actually freeze up the aperture blades solid, probably due to surface tension.
Yes it can! I bought a 180mm f/2.8 CZJ Sonnar in Pentacon-Six mount that had been sitting for a long while from all indications. The aperture blades were frozen wide open and wouldn't move in automatic or manual mode. I wasn't sure it even had blades until I disassembled the lens! Now it works beautifully.
BTW, I've gotten pretty good at putting aperture blades back in. A little patience, a steady hand and a good vocabulary are all that's needed! 😀
Walker
