Coding - Summicron 50mm recognized as 75mm Summicron
If you are off by just a millimeter, the camera will not recognize the proper coding. Make sure you have the coding marks in the exact position. A 50mm lens does not have to be coded properly on the M8. It is a must for wide angles though. Especially 28mm and less. I wouldn't worry too much about it!
Yes i know, but the code of the 50'cron is totaly different to the 75'cron.
Perhaps the problem is the bayonet itself? It has a screw, which is directly over the IR-sensor when the lens is mounted.
I know that's not really necessary, but it's nice to have correct EXIF.
The permanent marker works fine with my CV lenses. (21 skopar, 35 ultron, 50 nokton)
