Brad Bireley
- Local time
- 8:26 AM
- Joined
- Mar 10, 2006
- Messages
- 920
What type of cold weather gloves do any of you use to photograph in cold weather?
Thanks,
Brad
Thanks,
Brad
Disaster_Area said:I used to use the fingerless kind, but I found they didnt really do the trick in REALLY cold weather. Now I use these gloves I found at a hardware store. They're the usual thicker spandexy kind but have a layer of rubber and sand mix over the palms and undersides of the fingers. The grip is fantastic, and they're thin enough I can still handle the controls. Plus, the rubber layer means the underside is waterproof! This is the one case where having very large hands has paid off. I dont think theses gloves would work very well if they where even slightly too big for me. Usually one size fits all means my hands are left spandexed into a claw shape, but in this case they fit perfect. Some of my freinds use the lowepro gloves, I had a pair, but didnt find the grip to be grippy enough and they wheren't a proper fit, so when it gripped, the grip would stand still but my fingers would slide around inside the glove. This is where my new gloves really shine, because the grip is one contiguous peice instead of little patches of grip, your fingers gripping something cant slip away from your palm.
Ok yeah.. I know kind of a long post over gloves, but when you live through Candian winters you learn to take things like boots, gloves and proper socks very seriously 🙂
