Compressed Air / Rocket Best Pre Scan Film Cleaning
bwcolor
6:29 AM
S.F. Bay Area
Can I just pick up "Dust Off" compressed air from Costco and blow off the film just prior to scanning, or should I be using some more exotic/expensive compressed air products? Does the various size rocket blowers do much to clean things up? Where does the the anti-static brush come in vs. compressed air? I know that I have done a lot of moving dust around on a digital camera sensors. I'm trying to get some pointers regarding cleaning B&W film since digital ice won't be at the party. Also, what other products do you use? For example I picked up some Fotospeed FC50 Film Cleaner and cleaning pads for the glass such as Kimwipes and Pec Pads.
Thanks
Rocket blowers work as well as anything else and won't freeze your film.
True enough, but when I'm knee-deep into an hours-long scanning session, having a can or two of compressed air can be quite a relief. (Try squeezing one of those Rockets 30 or so times in the course of several hours...it gets old pretty fast.)
The best solution is to find a quality air compressor–preferably one that has a decent moisture trap and a motor that doesn't make too much of a racket. But that only makes sense if you're used to having long scanning (or, in the wet darkroom, printing) sessions. If you're only doing the occasional scan, the Rocket can suffice. A good anti-static brush is another good thing to hae as well.
- Barrett
Someone recommended me a brush for make-up purposes made by Artisan and Artist. Very soft and made of squirrel hair. I use nothing else ever since.
http://whatthestigma.com/web/index.php?option=com_virtuemart&page=shop.browse&category_id=32&Itemid=64
Works very well. Just as long as it doesn't touch anything sticky. The dust can easily be removed from the brush by a few light taps. A bit expensive though.
I had never used compressed gas. But my experience with blowers wasn't very good. Once something in the blower messed up my negs and I wasted precious darkroom time washing and drying.
