Freakscene
Obscure member
APO aint apochromatic, though.
Here: http://leica-users.org/v13/msg13490.html Erwin Puts points out:
"Now there is no industry norm that first describes which glasstypes you have to use to make a lens an "apo" and secondly describes which numerical deviations are required for such a designation."
If you use the absolute definition: i.e. an optical system corrected so that
it gives three images of identical size for three different spectral lines
or regions, you'll find that there are no APO lenses in current production, including those made by Leica. There are, however, several lenses that
are lens that has been corrected to a greater degree than in most other
lenses for the three primary spectral colors, including the R&M 90 APO
ASPHs. The differences in image size and therefore the 'degree' to which
the Leica APOs are apochromatic is an interesting study in itself. One thing is for
certain, they are better colour corrected (closer to the absolute APO) than
the majority of other current lenses.
Anyone with sufficient masochistic tendencies can calculate the (apo)chromatic error.
The other little-discussed influence is that the chromatic error decreases with stopping down, at least until diffraction makes it worse. At f8 or thereabouts, it is minimal, in all optical systems.
The true APO lenses for my microscopes cost about twice as much for a lens as an M9, but the lenses are about the size of your thumb and don't have an aperture or focusing mechanism. It is very difficult to achieve with camera lenses and not really necessary. 'Good' correction, such as is offered by the Leica APOs (excellent, really) will very, very rarely show any chromatic abberration.
Superachromatic lenses are corrected for four spectral lines but are mostly theoretical unless you have access to the kind of lens systems used in space, high end military . http://en.wikipedia.org/wiki/Superachromat There are Zeiss Superachromats for the Hasselblad: http://lenses.zeiss.com/photo/en_DE...ad/500_series/telesuperachromatt56350cfe.html but I don't know how fully corrected they are across all four spectral line. Very well, I guess, but I don't know if they really do all focus to a single point.
Marty
Marty
