Contact printing question
colyn
ישו משיח
4:28 AM
CowTown, Texas
If you've had anything delivered in bubble wrap, you'll find that the stuff with 1/4" bubbles is just about the correct thickness to replace the foam in the Paterson contact printers; I've just checked it against both the 35mm and 6x6 versions. Put the smooth side up and it should work quite well.
