contax G2 main switch going loose
photovdz
2:22 PM
hi all
The main switch of my contax G2 doesn't click anymore, it goes from one position to the other (off, on, AEL) without any resistance point...
very problematic since a very light touch makes him on... and
does any one has had and resolved the problem ?
Hi. I have the repair manual for the G2. I have looked at the main dial assembly. If you are lucky, only a spring has worked its way out of its seating, leaving you without clicks. To reseat the spring you will have to lift the cover, which is a fair bit of work. If you pm me your regular email address, I can send you some scans, which explain the procedure.
Jan
