fbf
What makes you find the G-M 21mm lens better than the ZM 21mm lens? I have neither one.
It was rated #1 wide angle lens in 35mm system, period.
The 21mm viewfinder is superb as well.
A beautiful piece and a must have for g system (don't say u have used G system if you haven't tried it yet). It is that good.
The conversion cost is more expensive for 21mm
"Optically, I prefer the Zeiss-for-Contax G 21mm f/2.8. It's slightly sharper wide open and has far less distortion than this Leica 21mm f/2.8. I can see distortion with this Leica lens, but I can't see any with the Zeiss-for-Contax G. According to the manufacturers' data, the Zeiss-for-Contax G has only one-third the distortion of this Leica lens. That's because the Zeiss lens appears not to be a retrofocus design, while this Leica lens is."
Quote from 21/2.8 Leica review.
If I could only have one Contax G lens this would be it.
raid
Dad Photographer
I may have to get me such a lens. First, I need to explore the 28mm, 45mm, and 90mm lenses.
jmkelly
rangefinder user
They often DO mention shortcomings, don't they! Honestly I think its just rationalization for having spent more on a G2 compared to a G1. The finder is, um... difficult on both bodies. Performance, speed and noise of the AF between the two is close enough that one could drop a hankie over the difference. The G2 is just bigger, uglier and more expensive, IMHOComments of G2 users often mention the shortcomings of the G1.
And yes, much as I love the 45mm Planar and 90mm Sonnar, the G Biogon is the gem of the lineup. It is the only 21mm lens I need or want. When my G1 dies and there are no more functioning bodies left on eBay, that is my one lens I will surely send to MS Optical for conversion to M-mount
Hacker
黑客
There is still the Leica 21mm f/1.4 to compare with!
Looking forward to that comparison!
jmkelly
rangefinder user
True - and I drool in anticipation, even though at 77mm x 70mm dia and 580gThere is still the Leica 21mm f/1.4 to compare with!
Frankly I hope a bunch of people buy them as soon as they are available, after which I hope the usual suspects give the lens horrible reviews - then I might be able to afford one!
raid
Dad Photographer
They often DO mention shortcomings, don't they! Honestly I think its just rationalization for having spent more on a G2 compared to a G1. The finder is, um... difficult on both bodies. Performance, speed and noise of the AF between the two is close enough that one could drop a hankie over the difference. The G2 is just bigger, uglier and more expensive, IMHO.
John,
Your posting makes me feel better about having bought the G1 and not the G2. Thanks! I saved some money, and I have three beautiful lenses to enjoy.
S
Socke
Guest
I have both and I prefer the G2 over the G1. That :bang: distance dial on the G1 makes me
LeicaFoReVer
Addicted to Rangefinders
Guys, I saw an advertisement on ebay that there is a bayonet adaptor for contax g- lenses to leica-m. Is it viable? anybody tried it instead of converting the lens mount?
thanks...
I may want to trade my elmarit-m 90 and get a zeiss 90m then as I am impressed by the results. Anybody compared both?
thanks...
Do you have a link to this adapter?
The flange distance between Leica M and Contax G is so close I don't think there is room for an adapter.
Not to mention, how would one focus?
sniki
thanks...
I wonder how could work such G-to-M improbable adapter: Contax G lens are autofocus; nevertheless these lens are really something good!
So good that - in my personal opinion - worth the cost of Japanes Exposures conversion packages.
BTMarcais
I'm thinking about doing the conversion too. Great lenses.
I'll at least do the 21mm when I get some funds.
Raid- I never had any issues w/ focusing or using the G1, and always had fun using it. You'll do well with it once you get used to it.
Since I got the G2 though, the G1 really doesn't get used much, unless I need a 2nd body.
I just like the way the controls are set up better, although I realize that's just my personal opinion.
(i like the controls on the G2 EXCEPT the drive mode dial on the left... I've bumped that a few times by accident and ended up on multiple exposure w/out realizing it... a dozen shots lost the first time I was in amsterdam...ouch)
LeicaFoReVer
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=230271723915
Sorry guys, after reading it carefully I realized that it is for Contax C/Y lenses...I was too excited I suppose.
So for G lenses I need to have them converted, right? I saw a name while reading the forum. I live in Canada and I wonder if I can manage to have a zeiss 90mm lens converted for my M6...
Thanks
Thanks
raid
Dad Photographer
There is a possibility that another person will start to offer mount modification of G1-G2 lenses into M lenses. Once I know more about his progress, I will let you know.
ferider
If you like the Contax G 90/2.8 look, and want it with M mount, an easier way might be to get the M-Hexanon 90/2.8 instead.
John, we are still waiting for your comparison
Roland.
Roland.
uhligfd
I have solved this problem in the following way: every third film somewhere along the pics, I would have exact duplicates. What would have happened is that the little left side dial had gone off its S setting to C and my finger was too long on the shutter button to be done with one shot. I did hear the double exposure clicks and I knew!
This i traced to slight rubbing of the left top corner of the G2 when i took it out of its confinement occasionally.
So I got my trusted bright red nail polish bottle out and dropped one miniature red dot (of Leica fame, no less) on the dial where the S is and another red dot on the - indicating mark on the body itself. Now it will be visibly obvious if the dial has been disturbed. No doubles since then. Good. And I can quickly check this even in the dark as well.
tbarker13
shooter of stuff
It's late and perhaps I just missed it in the thread, but who's Dirk? And more importantly, does he have a web site or a way to contact him?
jmkelly
rangefinder user
I have had the M-Hexanon for a while and like it very much - the build quality and handling on the KM lenses was just superb. I shot a bunch with the M-Hex on the R-D1 when I first got it - have it on the Hexar now with a roll of HP5+ in. I have a roll of Ektar in the G1 just now.If you like the Contax G 90/2.8 look, and want it with M mount, an easier way might be to get the M-Hexanon 90/2.8 instead.
Roland.
When I get both those done (been crazy busy at work, and heck it's been raining every day I have had time to go out and shoot) I will put the same film in both the G1/Sonnar and the Hexar/Hexanon and do some side-by side shooting. Maybe the innacurate AF of the G1 and the difficulty of long lens focus on the short-EBL Hexar will even things out
If anyone has a MS-modified 90mm Sonnar they want to lend me for a week, I will shoot it and the Hexanon on the Ikon for a better comparison.
