Correct hood for Serenar 100mm f/4?
bennyng
Benny Ng
11:12 AM
Tokyo/Singapore
Hi guys,
Does anyone know which is the correct hood for Serenar 100mm f/4?
I understand there is a 5cm slip on type as well as 3 variants of the 100mm slip on type. Are there any designation or markings? Or better yet, does anyone have any links to any pictures?
Any help will be appreciated. Thanks!
Chees,
It is clearly labeled as such. Quite rare, rarer than the lens by far. Series VI threads, with usually a 36mm slip-on Series VI adapter. There's a short narrow part that matches the threads, and then it expands about 6mm larger in diameter for the rest of the hood.
Can't post the pictures I've saved, they were from eBay listings, and the owner retains the Copyright.
HI Benny,
What T# 100mm f/4 lens are you chasing a hood to fit
My book in the hood row gives you a T# so let me know which T# it is and I can give you the exact engraving on the hood you require.
Cheers
Peter
