raid:
Every time I look at this photo I see it somewhat differently. I think that's a good thing.
My first reaction was slight annoyance. Here's a sparsely populated scene, an empty bar with surveillance cameras... "why cut off the bottom of the building and kill our frame of reference?" I thought.
But wait. I closed it and looked again later, seeing a very graphic presentation. Now the things in the photograph were free to be shapes and work abstractly. Everything from the unlit neon sign to the "peeling" awning, the man on the beach to the cameras became objects on the tabletop of the photographer's eye. The wide areas of flat tone started to make a lot of sense at this point. I wouldn't want any more detail in the sky for example.
I would want to spend more time looking at your work to see how this fits or doesn't fit.
I think this photo offers a puzzle that's fun to play with. I think it would be much
stronger presented with images in a similar vein. That's not really the point of this thread, but if you had this between two other photos of equal abstraction, it could be quite exhilirating.
Thanks for showing it!
David.
__________________
Raid:
A nice abstract shot. At least initially I see this as an abstract composition of shapes. It is nicely balanced then by noticing the figure on the far left in the distance. It also helps that the sky was fairly clear and it has been darkened perhaps by a filter. Perhaps an alternative version might include a little more of the beach itself in the foreground.
__________________
Mark Tomlinson
It appears to be a photo exploring abstraction. Large shapes are defined with small quirky details. I like the shapes. The tones are velvety in the photo and I can sense the strong colour and bright light, even though the photo is monotone.
Is that a negative scratch on the right? What are your feelings about retouching that?
The picture feels a little unbalanced in the composition. In painting class my abstract teacher would talk about creating a "push-pull" in how you portion out your shapes to make the surface more dynamic. The building is very heavy in the left-hand side and is not counter-balanced enough by the composition. Though I'm not suggesting that you crop this photo, I have attached crop below that seems more balanced from the perspective I'm discussing here. I hope you don't mind and that this is a useful exercise.cise.
Serius
Raid - this is a very sharp photo of a building on the beach. The window on the building with lights and security camera seem less interesting than the background with people walking on the beach, but the sun shade on the building is interesting. The photo is tilted to the left very slightly and there may be a small negative scratch on the far right, but the texture of the grain and the subject of the sky with clouds works well. I wonder how this would work with an extra inch of sand at the bottom? Very nice photo.
Ted (AMPGUY)
Thanks for all the comments on my image of the building at the beach. I started out taking beach photos, but then I wanted an abstract image. I had the Summicron lens on a camera, and I was looking for something more interesting than waves and sand. The geometry of the building caught my eyes, and I found the beach as a complementing factor to the building. I deliberately downplayed the role of the beach since I wanted to keep the building be the main factor. I will post the original color slide here. The posted image is a B&W converted image from a color slide.
I don’t mind the suggested cropping. I know that some people take offense that their masterpieces have been altered  The image is very sharp, and it was a test of the old 90mm Summicron lens hand-held.
I need to check whether this is a negative scratch or something else, Ted and Serius.
I took this image in color,and when I compose with color film I compose often differently than when using a B&W film. With B&W film it is more important to balance composition since everything is a shade of grey, but with color, sometimes a small part of an image area wise is actually "large" impact wise. For example, I added a small slice of the water, but it is blue and I envision the vastness of the ocean, so the small part of the image is [to my eyes] large. In that sense, I composed the image as balanced to my eyes. Changing the image to B&W, it may have become "corrupted" in the eyes of some people. I am trying out the B&W conversion to see if it is now graphically stronger than before or not. What is your opinion on this point?
I find Ted’s input fair and balanced and definitely a contributing positive factor as a “Guest”,don’t you think so?
Raid
