Jesse3Names
there is an eBay seller named Heavystar who sells new 4x5 Crown lensboards for about $16.00.
There are two types of Pacemaker Graphic lens boards I found: one with small raised bumps on opposing sides and one with both those small raise bumps and slightly rectangular-shaped raised bumps on the other sides as well. The one with two sets of bumps is labeled as a Super Graphic lens board here. Can the Crown Graphic use both of these styles and in what orientation does it go into the front standard? Also, is it a simple DIY operation to mount a lens with shutter (like the one I'm getting from eBay) to a lens board? I think they just screw on, but I'm not positive.
Someone locally has a Schneider-Kreuznach Angulon 90mm f/6.8 available that's in impeccable shape. The Synchro-Compur shutter it has sounds like it's accurate (hasn't been measured), but the lever used to select aperture or shutter speed, I can't remember which, will not go all the way over to either the smallest aperture or fastest shutter speed. It seems to work fine, just that one little thing. I don't know how to work on it, but it seems like a good option if this G. Leitmeyr Munchen Weitwinkel Anastigmat 90mm f/6.8 ends up being too bent out of shape to be worth paying for a CLA.
