willie_901
Bill,
I suspect there are many solutions that can produce excellent prints.
Just use what works well for you. The combination of the user experience and the product (print) is all that counts.
The user experience means the application is easy for us to use. Someone who started out with Photoshop for 20 years ago will use PS. Someone who prefers applications with a user friendly, intuitive interfaces might hate PS.
For what it's worth:
I calibrate my monitor regularly.
For digital images
o I use Lightroom Classic CC (OS X).
o I always work with raw files.
o Sometimes I use the legacy (2012 Google) OS X version of NIK Silver Effex Pro 2 as a LR plug in
For 35mm B&W film
o I use a PlusTek 7600i scanner
o I do a one scan pass at 48 bits per pixel
o Then I use the Vuescan preview to optimize Skew and Crop parameters
o The scan is saved as a Vuescan raw DNG file using the Raw Output with Scan option (grain or IR correction not invoked)
o This DNG file is essentially a flat TIFF file - except for the Crop and Skew corrections there are no other VueScan rendering adjustments
o The DNG file rendering is then optimized in Lightroom
o I often use NIK Silver Effex Pro 2 when a negative was ill-exposed and, or ill-developed.
o I also use NIK Silver Effex Pro 2 when I film and digital images together for a project or series. It is difficult or impossible to render a film image comparably to a digital image. I find Silver Effex Pro 2 is a convenient way to render digital images similarly to film images.
For digital images
For 35mm B&W film
