chadmopix
Hi. I'm looking for some advice on two 35mm Voigtlander lens, specifically the 35mm/2.5 PII and the 35mm/2.5 Color Skopar screw mount to be used with an M-mount adapter.
I currently use a 21mm/4 Voigtlander and a 50mm/2 Zeiss ZM (both of which are great) on an R4A and M6 respectively, but I'm looking for something fairly compact, or at least something that doesn't protrude as much as the 50mm. The pancake seems like the obvious answer, but the screw mount 35mm seems quite compact as well, even with the built-in hood.
I haven't been able to physically handle the lenses which makes a direct comparison difficult. Also, I should mention budget is a real concern.
Can anyone advise on the actual size/depth difference between these lenses, their overall quality and sharpness, or just their experiences in general with either lens?
Thanks very much!
Thanks very much!
