deardorff 8x10 owners
rgraphex
8:45 PM
I have bought a deardorff 8x10 v8 in pieces stored boxed for years. I'm restoring.
I stripped the lacquer leaving the original color replaced with nitrocellulose lacquer . Wood work is done. Now I'm replating nickel over half done. I think it was satin finish.
Washers what are the order? one large against the standard then smaller? is there a spring washer on every knob? a washer against the knob?
Dry fitting freshly nickel plated parts. I suspect 1 washer on each side plus 1 against the knob. Help needed
That's a gorgeous camera! Sorry I can't help you with the washers, but best of luck and happy holidays to you,
Steve in New Mexico
I've worked on it for months nice fresh lacquer able to flex with temperature and humidity changes to resist cracking sprayed on 5 coats semi gloss finish. Most of the nickel was peeling replated nickel I think 3 washer to screw just not sure. Need to be sure before I fold over the top thread.
