Roger Hicks
Dearest Roger
This lens is very flexible. I dare say it takes some time to get into it. Who says its "inferior" with the exception of your eminent self?
Zero depth of field at 1.4, but by f4 / 5.6 Ill bet you could not tell it from your 75 ;cron. Size and weight agreed. But people shot weddings with MF for years and never complained. Its not that heavy🙂
Richard
Dear Richard,
I have no evidence that it is inferior, which is why I said 'alleged to be', i.e. I have heard this from others. I also said that this would be unlikely to matter to either Dave or me, if it were true.
On the other hand I'd be astonished if it were as good at f/2 or even f/2.8 as the (more recent, slower, aspheric) Summicron but indeed by f/5.6 it is hard to tell most good lenses apart. Even then, I'd guess that test-chart addicts would see significant differences: I doubt the Summilux can reasonably reliably deliver 120 lp/mm on the film at f/8, as the Summicron is the only lens I have ever seen that has done so with my testing procedures.
Point taken about MF, but that is a bit apples-and-oranges: for me (and I suspect for most) a lot of the attraction of 35mm over MF is smaller size and lower weight, so I prefer to avoid large lenses on Leicas whenever possible. Then again, 'whenever possible' is a purely personal choice, and therefore a weasel phrase.
Roger
