What we're up to now is rebuilding the chassis, as I alluded to in some other recent posts. Every dimension of the earlier chassis is increasing slightly, the supporting panels are increasing in thickness (for rigidity), the aesthetics are changing slightly, etc.
A whole bunch of fresh mechanical parts were ordered, along with several meters of 20x20 V-slot, which forms the frame of the chassis. Just yesterday I finished cutting it to the required lengths, and I confirmed that you can infact cut it comfortably with a hacksaw (i.e. you don't need an expensive dropsaw), and drill holes in it properly with a power drill (i.e. you don't need a drill press or whatever they're called). Interestingly, oiling the blade of the hacksaw made it so much easier than otherwise.
So now, after scavenging some stuff from the previous chassis, we now have a pile of bits that will form the main section of the final scanner. The main thing left to do is to use a laser-cutter (my uni has a couple) to chop up some acrylic for the side supports, that should be done by next week, and then we can immediately begin assembling it together. Pics of it should follow.
I've also been working on the software/electrical side of things too, I've been involved in some other projects recently using OpenCV, which I think will be super suitable for fast image previews and maximum-quality final image output.
Regarding kodak licencing - I mean it's not a bad idea, but I'd prefer not to mess with that sort of businessy stuff regarding film anymore, otherwise I'd have to take this project a bit more seriously which might kill the fun factor.
Anyway, a brief update for now.
