Yes we were able to get some test images back in 2015 or so, however that was really representative of the sort of results to expect if we ended up successfully designing the rest of the scanner infrastructure/hardware to support it; and although we've gone through a range of ideas and prototypes in an effort to find a design that is even partially acceptable, we are really yet to find one. However, as always, we're close to significant progress for a very satisfying design. But - if anyone would like the design files of our earlier versions, send us a message and we'll help you build something like where we got to before realizing it was a dead end. There are just so many metrics of acceptable design - rigidity, simplicity, manufacturability, part-interdependence and alignment requirements, ruggedness, whether each of the innumerable sub-modules actually works, the design inflexibility behind committing to a given mount for modularity, etc etc.
The reason we build prototypes is to test and get feedback, we have taken this onboard and what we are currently working on is just the next step, which includes a few redesigns but no radical departures from what you know.
Regarding emerging tech, we agree it did sound a lot like vapor-ware when we were writing it. This was us trying not to disclose (and thus becoming sort-of committed to) which new technology we may be experimenting with.
We are also disappointed with the speed of progress but there is only so much we can do as a small team with limited funds and time.
But we don't need to winge, we are legitimately onto what might just be the final real design iteration.
On another note, I (quejai) have recently taken a part time job designing the electronics/computer/interface for obscure research lab equipment. I'm planning to use a very similar approach for the electronics/computer stuff in this scanner as, really, it's quite similar. My starting point at the job was the architecture I developed for this scanner, so to be quite honest, progress on this front is blazing (the arduino and raspberry pi combo in the pictures are just for this prototype/mockup, they are not part of our final computer system). Coincidentally, one of the mechanical design people in that company has great contacts for getting aluminium parts manufactured, which will come in very handy later on when we start replacing the acrylic in our prototypes with aluminium.
I'm also doing a uni thesis on dust/scratch correction methods. For this, it is becoming increasingly important to get some more image data, and hence there's a bit of a rush to get some sort of partially-working scanner that can produce image output yet be legit enough to provide repeatable, controlled results. This was taken as an excuse to take the latest scanner design and build a mockup with the parts we currently have (ie we can't afford all the proper optical elements yet, so things aren't quite as specified in our main designs - but close enough for now). Our latest chassis designs combine the focus and image-carriage level from the last prototype into an extremely compact setup, with so little to go wrong it is vastly easier to build, and really ought to never break or jam - our previous approach was otherwise. Again, this particular build is a prototype, but it is essentially what the latest chassis design is.
A fun fact about this new focus system: each end of the carriage's motion can be focused near-independently. This avoids the scenario where focus is correct at one position along the carriage's motion but not at others. In effect, it may appear as a slight 'tilt' - this image gives an example of an unrealistically extreme scenario to point out the capability. We'll have videos of this adjusting itself soon. This is a very good thing!
Now as we're using the older optical setup, we need a bit of extra clearance below the chassis for some cabling. We also need a stand-in filmholder, as we haven't quite finished designing / can't quite afford the parts for the latest universal filmholder design, we're going for a super simple non-mechanized flat approach. We also need a light source, so we're experimenting with a softbox-inspired diffuser. It's huge, it's also easy to make, so we're taking this as an excuse to try out the idea.
Yes it is a bit of a timing coincidence, but the primary rush for this is so it produces image output asap for a uni thesis. Over the next week or so the wiring up will be completed, and we'll keep this thread posted with progress. Watching the focus system moving is quite revealing of how it works, expect a video when we've got that going electronically.
The next work steps for this scanner is to order the parts for the more compact optical setup, and to finish off designing/ordering parts for the film holder.
The final-product scanner that I've got in mind is essentially what we'll have once those are done, just tidied up and neatened. From the outside, it will look quite a bit different than this prototype though.
