Hey again! Here's another update on the development of the prototype since my last post:
Overall: Things are going to plan - but slower than expected. We're about 2 weeks behind where I wanted to be, which means that there aren't any sample scans to release this weekend, and starting the kickstarter is similarly delayed. This all sucks, but it could be worse.
I know we really need photos of the actual scanner itself, but I haven't got quite enough parts to be able to assemble (and thus take photos of) it yet. Stay tuned, though...
The final order for electronics (mainly for the strobing kohler backlight system) has been ordered, and arrived last week. This includes some really fast switches, which will enable sub-millisecond strobe periods. This is good!
[MOSFET switches above, R/G/B/IR LED's below]
The lens elements for the backlight system arrived. They're also a different shape than I was expecting (convex-convex instead of convex-planar). This has resulted in a slightly more complex design, but it's not much of a problem. Just for kicks, and because the price was barely more, we're using two aspheric elements here. To clarify, we're using conventional microscope optics between the film and the sensor, and a custom optical system built from these two lens elements between the LED light source and the film.
[The two aspheric lens elements for the light source system]
The 20x lens has arrived! Currently, I have the microscope lenses hooked up to a nikon J1 for some testing, but the depth of field is so narrow that I really can't get any useful images from this lens at the moment. Once the scanner is assembled, it'l be a different story.
Parts for the prototype's housing have been obtianed, this is a lower priority but a good deal presented itself and I couldn't resist the price for these parts.
One of two lots of hardware has been ordered, and too has arrived. This batch is the small-tolerance industrial stuff that ensures accurate alignment between moving parts, and also provides the mechanical 'skeleton' for the scanner. It's lighter than I thought, which is a plus, and it's really nice to work with. Beams, motors, bearings, bolts, etc.
[assorted bits]
The second of the two lots of hardware is the problematic, delay-causing one. It's the most complex order, and requires about fourty parts to be very carefully defined prior to the order. Long story short, it's frustrating and unsatisfying - every design decision leads to redoing another, and then optimising another, and so on. Another 20 hours of work on this part and it should be completed, but I've been too busy with other things this week to really knuckle down on it.
A positive thing is that this will be the final parts order; everything else is just assembly, testing and programming.
Earlier on, I mentioned cine-film holders. I've decided that, at the moment, this would have a very small user base; so for the moment I'm not going to work on these holders. If there is enough interest in the future, then cine holders could definitely be released later on - but the design difficulty just isn't justified at the moment.
Current rough schedule plan:
10/11th - submit order for the above mechanical parts
15/16th - mechanical parts arrive
18th onward - sample scans!
Once we get a working prototype, instead of starting the kickstarter soon after, instead I think it would be a better idea to spend a couple of weeks ruthlessly testing and noting down design improvement ideas, so that the model you'll actually have the chance to buy is as good/repairable/reliable/etc as possible. This is also the point where I'll try to get a team together, as there's only so much a one-person-team can acomplish. I know about 20 people who are keen to get involved, but I'll try to whittle that down to a more reasonable 4 or 5 main people. So around mid-late January, we'll probably give kickstarter a go, and see where that takes us.
By the way, check this out!
http://www.cmosis.com/products/product_detail/chr70m
It's a 35mm-sized 70 megapixel sensor. Now it sounds pretty ridiculous, but regardless I'm pretty keen to see what new cameras come out using this.
