Developing Tri-X in HC-110
sooner
2:36 AM
Oklahoma
Hi Folks,
Well I did it again, getting my math wrong and developing a roll of 35mm Tri-X 400 in HC-110 dilution B for 7.25 minutes. Thought I had mixed dilution H, 'cause usually I'm mixing more chemistry for 120 film. The film came out very dark, though some may still be usable. This motivates me to ask a question I've had for a long time: how long do you develop this film in HC-110? The big development chart online lists three or four different times, from 3.75 minutes to 4.5. Very annoying. Thanks in advance.....John.
Obviously dilution makes a huge difference. So does the metered speed of the film.
I tend to push my TriX - and so I use HC110 at 1:100 in a semi-stand development. 1 stop push = about 30 minutes, with one inversion every 5 minutes.
that said - if I'm using dilution B, shot normally. I would process for 4:15. But I hate feeling that rushed. 🙂
For 35mm Tri-X at 400 EI in HC-110, Dil B...
After some trial and error, what works for me is 6 min, 15 sec at 68 deg F. I apply 10 inversions from the outset, then another 6-8 inversions every 90 seconds.
You can see some of the results in my Jerusalem photoset. All the B&W images are from HP5+ and Tri-X -- all at 400 EI and all developed in HC-110, Dil B. I forget which ones are which, but in general, the B&W images with the slightly higher contrast are the ones shot with Tri-X.
Good luck!
I'm about where Chris101 is. I shoot TriX at 250, develop HC-110h 11.5 minutes, 30 seconds agitation to start then 3 inversions on the minute, 68 degrees. I like my negatives a little dark so you could even go back from this. But for Trix at 400 (which I didn't like) in dilution H, I used 12.5 or 12 minutes which is close to Chris' B dilution.
I'm nearly in teh same boat with John (also used to listen to his advises when was going through trial and error with HC-110 for Tri-X in the past).
Settled for 12.5 min. for Tri-X @ 400, 20 deg. C. Moderate agitation: first 30 sec., then 3 inversions at 2 min. intervals. Of course, dil. H.
Interesting. If I shoot Tri-X at 400 in especially dull lighting, I'll dev it in HC-110 dil B for about 7 mins (I find 15 to 30 secs either way, in whatever dilution, really doesn't seem to make much difference). For exposure at 400 in good lighting, I prefer dil H for about 14 mins.
But I like Tri-X best at ISO 200, done in HC-110 dil H for 12 minutes.
