roscoetuff
So I've wondered and looked and it's curious that a number of folks have written here and there that they have motorized their agitation using a Uniroller Base to roll, reverse direction, and continue rolling for B&W. Seems these things were made for color... just to make it confusing, but sounds as though the idea is aimed at doing something similar (but much lower tech) than a Jobo... which I have only vague ideas about what they do.
But recognizing that the new Kickstarter project "Lab Box" is a constant hand wound development process.... I'm curious about the whole. I've kept reading and seen that some folks who bought Jobo's eventually stopped using them for anything other than the motor. Theory has it that a motor controlled process would give more repeatable results, but the annecdotal reports seem to suggest the degree of difference between mechanical and a solid hand routine is less than meets the eye.
For my part, I'm curious... especially could see benefits in using higher dilution, longer development times in terms of freeing your hands up. More curious whether anyone out there in rangefinder forum land has been down these roads sufficient to have an opinion or especially experience they can share insight on? The roller bases are pretty cheap compared to a full Jobo machine!
