There are many variants of the VIOOH/Imarect, which are mostly only relevant to obsessive-compulsive collectors. So long as you only need 35mm, 50mm, 90mm, or 135mm frames, any operational one will be fine. If you need settings for 73mm, 85mm, or 127mm, then you need to find the rarer ones with those particular settings.
