lZr
L&M
If you want to read/rewrite the HD, do Defragment in Windows. For iMac there must be special utility about
Rico said:I program and administer Linux-based machines for my company. Main storage is 5TB configured as 2x 2TB RAID5 plus miscellaneous. This is backed up incrementally over gigabit ethernet to Quantum SDLT II (300 GB native carts), using my own software. Certain tape sets are rotated to a bank vault. In six years, we have suffered two complete RAID5 meltdowns, requiring a complete rebuild from tape.
Whether you use a RAID system like 3Ware or a solitary drive, the periodic reading of all storage is recommended. If you enable SMART, a better measure of predicted failure is reported. In the case of soft errors (the first sign of bit rot), drive firmware will either rewrite the sector in-place and test for correctness, or relocate the sector entirely. The latter makes use of spare sectors that were allocated during the factory format.
Magtape is the only acceptable archival storage on this scale. Optical technology has insufficient density (4.7GB versus 800GB in the consumer realm). Hard drives include an integrated motor with wiring, insulation, and lubrication. Hard drives are also mated with an electronic board with perishables like capacitors, and unit-specific parameters like the defect map. If the motor or circuit board fails, disaster recovery of that drive is expensive or (in later years) impossible. Hard drives should be used for live data and for mirroring, and should be kept spun up 24/7. There is a significant issue around quality of electrical power and thermal cooling, but that is another boring chapter called "Building and Maintaining Your PC Farm". 🙂
rich815 said:But what's it all mean, Basil?
