Bappy1988
Hi Guys,
I'm probably in the minority here, but my main 35mm camera body doesn't allow me to override ISO 🙁
It supports dx coding for AE, but as it doesn't allow the user to override the ISO speed, I can't push unless I shoot entirely on manual and use an external light meter.
I've decided to make my own DX coding labels because I'm a lazy photographer and I like to let my camera do some of the work for me 🙂
So, in case anyone is interested, the process is simple. I use self-adhesive aluminium foil pipe/duct repair tape, cut a piece 33mmx36mm and stick it to the can tucked up under the lip where the film comes out. I then print out a dx coding label/template.
my dx coding web page
I wrote a simple php program (^link^) that takes your film parameters and creates you a jpeg for a dx coding label.
All you have to do is print this out on a piece of label paper @ 96DPI and it should measure 36mm x 33mm. Cut out the WHITE parts of the dx code section using a stanley blade/xacto and affix the label on top of the aluminium foil already there!
I've only just written the php program this morning (haven't fully tested ALL the possible combinations) and I've taken the values from a wikipedia article so make sure you double check that the dx code looks right before using (I won't be held responsible for any mishap that may occur as a result of using this program...)
hopefully others will find this useful. Please leave a comment if you use it and comment any errors or issues here.
Thanks & happy shooting 🙂
