Sparrow
What makes Raid’s question so contentious? Reading through this thread it seems to me to be impossible to argue either side convincingly without some sort of “belief” or “faith” being accepted as a truth.
On the crop-till-you-drop side the image itself is everything so it’s only the duty of the photographer to make the best possible picture. Now that’s fine with a family photo or a fashion shot, however it starts becoming ethically doubtful as you move into documentary or journalism the first duty is then to be truthful.
On the other side at least you have the moral certainty that you have “told the truth” and can prove it to the viewer with that ragged black outline, allowing you to feel “morally superior”? Except that’s not the case in reality is it? The same argument holds good for the whole film as for that one frame; if you have two shots of the same scene then you would certainly have the print both to keep the viewer full informed and you could argue all the negs in the correct order from any given location in order to maintain it’s full integrity, tell the whole truth that is
So as with many things the answer is “well……it depends” it depends on the photographers intention and the use the image is finally put.
