No because technology doesn't = better....
This technology further separates the photographer from the process thus making it easier for someone without technical skills to make technically average photographs under average conditions....
All that stuff on my so called advanced DSLRs got in the way of me creating.
Please explain how technology "gets in the way". I've heard this said many times. Please give examples. I genuinely want to understand this mindset. It comes up over and over.
You have PSAM modes. Set to "A". You have control over aperture. You roll a command wheel on your thumb. The aperture appears in the viewfinder. You don't even have to look at the lense. Shutter automatically adjusts. Nothing gets in the way.
Same with "S" except "A" adjusts. Nothing gets in the way.
Want to go full manual? S and A? Set to "M". Nothing gets in the way.
Just want to focus on composition? Set to "P". Really nothing gets in the way.
Want to go slow and methodical? Set shutter to "S" (single frame). Want to shoot continuous frames? Set to "C" (continuous).
You can set-up a modern DSLR, mirrorless, what have you any way you want and leave it alone. I have heard this "all this dang tech gets in the way...".
What I have never heard is "how" it "gets in the way"... As I see it, these features are "there" -- use what you want. Don't use what you don't want. You can it up any way you want, and leave it be. Some make it sounds as if you're perennially fiddling with dials.
You don't.
Or you can -- if you want.
I'd rather have these choices/features than not.
I'd counter that
lack of technology "gets in the way". I
like seeing the aperture in the viewfinder over having to take my eye away to set it. I
like choosing variable ISO (or not) instead of being limited to whatever ISO is on the box. I
like being able to quickly switch between the varios modes. All of which can be done in an instant. I
like having additiona modes that I don't use often or at all but are there if I want them. I
like, with the flick of a dial shooting single or continuous frames. I
like not having to look at an external light meter and taking my eye off the VF and fiddling with the lens barrel to set aperture. I
like autofocus but having the option of shutting it off and focusing manually if I want.
I
like slapping a (now) inexpensive radio flash control on the hot shoe, setting the flash to TTL mode, shooting in "M", setting up the flash on a table on a little stand, bouncing it off the wall, and shoot at any aperture/shutter combo and let the flash do the rest in terms of lighting. This tech opens doors for more creativity, as but one example. It eliminates fighting the photons and being forced to shoot wide open or with slow shutter speeds indoors.
All of which
lends itself to more creativity. More options = more creative possibilities.
Or? Don't futz with it. Set-up your camera and don't use any of it.
I've used (most of my life) straight manual cameras from SLRs, to rangefinders, to folders that didn't have light meters. I have used modern D/SLRS with many bells and whistles -- it's not that I haven't used all of them and have no basis for comparison. I simply don't understand this "gets in the way" mindset when I have the option of not using any of them in a modern DSLR, setting up the camera as I wish, and never touching another dial or setting if I so choose.
