Just curious if whether or not the M6 LHSA exhibits the same RF flare as found on the M6 classic. Anyone out there know the answer? I'm trying to figure out if the M6 LHSA might make a good alternative to an MP. Thanks!
The 0.85x cameras flare more than the lower mag versions. my pre-MP finder M7 0.85x had atrocious flare until I had it upgraded. It's still not as good as an M2, M3, M4 prior to the switch from the flat to the parabolic mirror in the frameline illumination mechanism.
I just wish I could get an M3 finder grafted into my M7.
No it does not flare as much. With the M6 Classic I can not focus when it flares, with the M6 TTL LHSA SE I can. I know, because I have a .85 M6 TTL LHSA SE. IMHO it is a good alternative to a MP. Especially when you have a M7/M8 as well. Because the shutter dial turns in the same way.
