emraphoto
It all matters, in varying degrees, depending on the individual.
This thread is a storm in a teacup!
It only needs to be stirred if there is sugar. Should we add some? This thread could use some sugar.
Check out these photos taken on a 4mmx5mm sensor in an android phone using a Kodachrome plug-in.
Pete
I think they were taken with 4"x5" Kodachrome film in 1942.😀
Why would Holgafying or Hipstamatic make a difference?
Here's the gist of most comments: it's a bad photo. Bad light, bad composition, bad mise-en-scene. No amount of processing, in any style, can change those things.
He used the photograph as an example of his point, that his post-processing made up for cheap equipment. The 'point he raised' is inseparable from the image presented - the quality of the photograph and the post-processing. Both of which are failures.OP: "Does the Camera Even Matter Anymore? Or is it about software/software skills?"… "Does gear - bodies, lenses even matter anymore?"
The point Nick discussed was not about his S/O, the quality of the photo, light, composition or mise en scene. So if you're discussing those topics you are not discussing the point he has raised. You might as well be discussing the hockey playoffs.
Yes, and as with the original image presented, software manipulation - and equipment - only matters insofar as the post-processing and the image itself are good. A bad image is a bad image, regardless.In regard to my comment about using a Holga or Hipstamatic image processing template the point was it is a software manipulation of an image.
....The 'point he raised' is inseparable from the image presented.....
"A camera is a mirror with a memory, but it cannot think." -Arnold Newman
The implication here is that while every photograph (of any technical quality) is, to a degree, a true representation of its subject, not every photograph is effective at conveying meaning or the qualities that inspired the photographer to make the exposure. Great images are produced by insightful minds -not precision equipment. Give a master of photographic expression a Holga and watch the magic unfold. Give a duffer a Hasselblad and prepare to be bored!
We need special equipment to capture an image, beyond the basics, everything else is a matter of degree.
