For now I'm still shooting with the T2 as my carry-on, at a rate of around 2-3 frames a day. In the evenings or indoors I'm doing just fine, it's quite discrete and with 800 portra I get decent speeds for hand held. Mornings and daytime it's a bit more limiting, camera always tops to 1/500th and I have to set it to program mode, so it's stopping down significantly I assume.
Meanwhile I've decided to categorize my options. So far I've got this:
Small SLRs with a 40-45mm pancake:
Olympus (not sure which one of them, need to start researching) with a 40/2
Pentax (again not sure which one) with a 2.8 pancake
Small contax (like the RTS II) with a 45 2.8 tessar
Canon kiss with a 40 2.8 pancake
A nikon with a pancake
Small M rangefinder:
CLE or a CL with a 40/2
Small fixed lens rangefidners:
There's ton of these, started making a list, looks like Oly 35RC or Koncia C35 could be a way to go.
Fixed lens AF 'rangefidners' (big point-n-shoots) – like the canon sure shot, konica C35AF and the likes
Premium point and shoot cams – T3 or Klasse S seem to be the only two suitable options.
I must admit that after 5 years or so without buying new cameras I've got a bit of GAS going on right now, so I need a reality check and have to list down two main reasons why I want to replace the T2:
1. Limiting exposure choices – fast speeds available only in program mode and when stopped all the way down.
2. It's never clear when the shutter is actually released
Then I've decided to make a checklist of stuff I want from a daily cam:
1. Some form of exposure automation – Aperture priority preferably
2. Faster shutter speeds available for all aperture values
3. 35-45mm lens, 43mm ideally (looks like only pentax has 43mm 1.9 lens)
4. Compactness. I thought if it's a tad bigger then the T2 I'm gonna be OK, will just screw on a UV filter on the lens and carry it inside the backpack.
If I didn't own a G1 I would probably consider it to be an ideal option, and would probably even buy one off ebay, but owning one the darn viewfinder is just so upsetting 🙁
