Does this lens have fungus or haze?
The lens is a 1959 Leitz Summicron 35mm/2.0
The outer optics look perfect (had front filter and rear cap)
I am not sure the value of the lens.. I paid $50 (garage type sale)
Haze is uniform. This will not come out with cleaning. Been there, done that with the same lens. Evidently this develops with time. mine is much less severe and I still use it, but there a a dozen of these whitish spots that don`t clean.
It is a parts lens or trash. E Bay it and you will get a bad rating
I never knew selling items for parts or repair on ebay gets you a bad rating...
I thought the bad ratings came when one lies about the condition....
Fungus will generally appear to be a central spot with many roads radiating outward. I just "treated" a 50mm f/1.9 LTM Serenar yesterday that had a fairly large "web" of fungus. A Q-Tip and Windex did the trick. Fortunately, the lens had not been etched so there was no damage that I could see.
Walker
I took the front off the lens.. The markings came right off.
There are some more in the assembled rear element.. not sure if these will wipe off. This is not a job for me.. I am going to send it out.. see what happens
This looks more like some form of sublimation of the lubricant. It should be able to be professionally cleaned. A tip I learnt ftom CRR in Luton is that it must be "wet" cleaned. If you try to "dry" clean it with a cloth, you are likely to make it so bad that the element will need to be re-polished and recoated.
Kim
