Does your Summicron focus-shift?
BobYIL
8:46 PM
It is not difficult to detect if a lens focus-shifts; we can also measure how far it does. First place two rulers perpendicular to each other as shown in the picture, the vertical one at 45 degrees to the horizontal axis. The number "20" is our reference point to focus and the testing distance is 1m exact from lens flange.
If your lens has no focus-shift then starting from wide open it will show such a performance (Nokton 50/1.5 Asph. @f1.5, 2, 2.8, 4 and 5.6)
The C-Sonnar is known of shifting focus. Here @f1.5, 2, 2.8, 4 and 5.6. This is a typical focus shift case:
Finally the reference class Summicron 50/2, current formula (!), @f2, 2.8,4, 5.6. Would you believe?!?
Conclusion:
If you like to use your lenses at wide apertures, then better be informed of how much they focus-shift with different apertures. Such optical discrepancies may become more apparent on digital bodies than film. Also sometimes they may deceive us by making us think our rangefinder needs recalibrating. Once you know how they "behave" then it's not difficult to compensate for such shifts.
Was this on film or digital?
Popflash have a note on their C-sonnar listing that states that the lens is optimized for f/1.5 on film, but on digital, it may be slightly different. Apparently the digital M have a very slightly different lens flange to sensor distance than film. With film, the manufacturer of the camera has to guess at how much bowing in of the film will occur towards the lens.
Norman Goldberg (father of DAG), has a detailed explanation of film flatness issues in his book on camera design.
The C-Sonnar shifts exactly the same on film and digital. Both M-flanges, digital or film have exactly the same register distances of 27.8mm. The digital, due to higher resolution, enhances the OOF-in focus differences more than what film does.
What Summicron? 50mm, 35mm, 75mm, 90mm? Which version of each focal length?
My 50mm tabbed (version IV) does not show any shift, and I have tested it using a method similar to what you describe.
"Finally the reference class Summicron 50/2, current formula (!),"
Mine is too the tabbed one and it focus-shifts.
Focus-shift is not a discrepancy based on sample.. it's a deficiency (or fault) of the optical construction.
I don't get it even illustrated so nicely, but my DR Summicron focus where I want him to focus to and rarely misses 😀
Regards,
Boris
True.. no shift is observable; here's the Summicron DR, from left to right f2, 2.8, 4 and 5.6.
I just dropped off my version IV 50mm Summicron at Leica in Nj for an issue that they identified as "back focusing". They are going to make some adjustments with the focusing helix, among others, and change the mounting flange. They tested it with test charts set up similar to your rulers, although the center focus target is a red Leica dot from a camera. It will be interesting to see if it focus shifts when I pick it up. Although, from your description it seems as though a lens that focus shifts cannot be adjusted, it is a design fault. Is that correct? One advantage to being able to drive to Allendal is that they guys in the back can answer your questions and play with things while you are there. I'll let you all know.
Are you sure it is not due to the lack of rangefinder calibration; i.e. you focus on the rangefinder to 100cm but on film/sensor plane it focuses to 105cm for example? (Naturally to be tested wide open only..)
Oh yes, they checked the camera at the same time; quite a nice operation really, they also cleaned the sensor for me no charge. I know this is not a big deal on and M8 but it is nice thorough customer service.
I check lenses after CLA. With similar to this:
http://www.firstchoicephoto.ca/FocusTestChart.pdf
Minimum focus distance, by 45 angle. I make zero line thicker with marker and use camera in portrait orientation.
I calibrate lenses on maximum aperture. My mint Cron 50 v4 focus shifts more than LNIB Nokton 50 1.5 and Planar 50/2. Rigid in user condition was also shifting, but less than v4.
