Domke F5
Fabri970
7:47 AM
Genova
Hi 🙂 ,
i'm lokking for a bag who could contain two bessa camera with attached the lenses (a Nokton and a Color Skopar 35mm pancake), plus 3 little lenses ( a CV 21mm a CV 28mm and a Summicron), i've seen a Domke F5, very beautiful bag but is it enough capacious to hold my lenses and my cameras?
Did you know the bag in object?
Thank'you in advance for the help.
Hi, last week has arrived to me the domke F5xb, very well made , inside i put two bessa, a R2 with a color skopar 35mm pancake, a R2a with a Nokton or a Summicron, and in the middle a CV 21mm with viewfinder and a CV 28mm with a viewfinder, i've added a foam in the sides of the bag near the hook of the strap to protect the camera body.
I've buyed it on ebay, with the shipment cost to Italy i've payed it $ 60 against 120 $ if i had buyed the bag in Italy.
I have done basically the same thing as Fabri970 describes (two cameras, each in their own section and an extra lens in the third section) with the Domke F-5xb. For what it's worth, I found placing at least one of the cameras in the middle section to make it much easier to remove and replace the camera. Also, regarding the extra lens that I placed in the third section, I put it into a thin neoprene cup (commonly referred to here in the US as a "cozy" to keep a can of soda cold) to provide extra protection. That way, I oould put other small items (e.g., finder, film, meter, whatever) in that same section without them banging against the lens. Hope this helps.
-Randy
