double exposure in ZI
Assaf
4:12 PM
Israel
Anybody seen it?
It happened to me a few times, and I think always after relatively long exposures (1/15 or 1/8). I attached two examples.
It's really annoying....
Anybody had it? Fixed it?
Thanks
Assaf
Make sure your index finger isn't hitting the rewind button on the bottom of the camera. It's probably more likely to happen when trying to handhold slow exposures since it's a stable way to hold the camera.
I've only had it happen once out of many rolls and I'm pretty sure I accidentally tapped the rewind button while winding on.
The frame on the left is caused by pressing the rewind button before recocking, the frame on the right is caused by a hasty and incomplete advance of the previous frame.
I've noticed that I sometimes get double exposures when I wind on too fast. In fact, the user manual specifically warns against this. Yes, the ZI isn't perfect. (Just very close.)
It's happened to me a few times. I suspected that I advanced the film too fast, but wasn't sure. I'll take more care from now on.
I reckon film advance is the Ikon's only minor weak point ... mine has never been all that consistent in it's spacing between frames and when I first got it it would tighten up when advancing every now and then. It stopped doing this after about ten rolls but the irregular spacing has never improved!
Same here, I have exactly the same phenomena.
But since it is a minor issue to me I just leave with it happily.
Still, after more than 200 rolls, I haven't experienced the double-exposure problem, as Assaf is showing.
Can't it be a defect in the camera?
I think a serious testing should be conducted, just to eliminate the by-user assumptions.
OK, I'll have a look to see if it's not a user problem. Maybe I touched the rewind knob or blocked the rewind wheel somehow?
I must say that I never experienced such a thing with any other manual film advance camera, and I used a few.
Am I the only one who INTENTIONALLY double exposes with his Ikon ZM???
I just love this camera, it is a fantastic Value for the money.
