GaryLH
http://www.focus-numerique.com/test-1546/compact-sigma-dp2-merrill-bruit-electronique-12.html
Dp2m, sd1, dp2x, x100, x2 base iso up to normal max iso for each camera..
Gary
Gary
Jamie Pillers
Skeptic
I keep hoping the Foveon-based cameras will make some great leap forward. But it looks like the Sigma designers haven't figured out how to use all that 'horsepower' yet. The Fuji X100 samples look far better.
Thanks for posting the link.
GaryLH
The only thing that bothers me is marketing bs about it being a 45mp sensor. It is a true 15 mp sensor. All sensor using a color array can only represent one color out of the three possible at each pixel location. A value from 1 to 255 is associated w/ odor intensity (8 bits, a byte is needed). The sd1, dp1m and dp2m each pixel location needs to represent three colors (3 bytes) thus 15mp x 3 --> 45mb raw files at min. Thus no color adjacency issue, no guessing that could cause issues w/ resolving a clean edge.
If I ever bought this camera I would use it within it constraints and not be worried about the negatives. Between rx100, x100, and xp1, I have other things well covered. Over 60 % of my photography is w/ landscape and inanimate objects. The ret is split between street, portraits and family related pictures.
Cheers
Gary
Ps another way to look at it, if someone were to produce a monochrome 15mp camera, in theory it should resolve the same detail as this sensor (dp2m) but w/ much smaller raw data size since no need for storing info on three color intensities.. Ala Leica monochrome...
Cheers
Gary
btgc
Absolutely don't care as long as there are enough pixels to make decent print (and there are enough). RAW file size bothers me more than this.
GaryLH
Yes point taken... Got enough ram to handle processing temp space plus raw CPU horsepower.
Gary
thegman
It is BS, but the entire industry is using the same BS, so Sigma has to go along with it. When they first released a Foveon camera, they did in fact use the "real" MP count, but because nobody else did, their MP counts looked very low.
Cheers
Gary
btgc
Yes point taken... Got enough ram to handle processing temp space plus raw CPU horsepower.![]()
My elder PC is slow already with DP1 RAW files. I think it's software as Pentax raw files at PhotoLab move faster.
GaryLH
I am confused by this part of response.. Can u elaborate?
Cheers
Gary
btgc
I'm comparing apples to oranges, maybe. But Pentax RAW get processed faster in their software than DP1 RAW in SPP. From what I conclude SPP is slower than Pentax PhotoLaboratory (ancient one, as SPP is). I'm not cross-processing Sigma RAW in Pentax SW or vice versa
GaryLH
I'm comparing apples to oranges, maybe. But Pentax RAW get processed faster in their software than DP1 RAW in SPP. From what I conclude SPP is slower than Pentax PhotoLaboratory (ancient one, as SPP is). I'm not cross-processing Sigma RAW in Pentax SW or vice versa![]()
IC. Got it
Gary
