E-P2 and Voigtländer lenses - beauty combo
coyanis64
4:59 PM
The E-P2 does not only take great photos, it is also a beauty when combined with Voigtländer glass 🙂
Heliar 15 4.5
png;base64,iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8%2F9hAAAAGXRFWHRTb2Z0d2FyZQBBZG9iZSBJbWFnZVJlYWR5ccllPAAAAXJJREFUeNqkU01LAlEUPfOhM6SOjJSBIK6yVgUtWgouWgcJLYN%2BQX8j2vUDWrcJWiZFCkH7domCmZJ9YqmjzpfP3jyYYUSU0AOXe9%2FlnXvPfdzH7Z0%2FgELEfLAdYhGLgCoojuaEw%2FWkn32aMLUaum8FRBK7CIaSMxsfx4PM824iYHdRyWdBGieoXGcQIH3IPD%2FVXHiRVr%2FEiipiPb2B5aiAXv0KYYGbai68EUjvBbIkgZAhJFnCiJ4V30U%2FBO0dUBPjCmKRJHRdpwUI9QPElCSokEkzWghVC5MjbKUP0PrR8Vyr4relY3MtRwkcQrRbxOqwWCEGuPItONucHGF1KYaj%2FTvcXBwilzlFXI6C2AZeS3nqTYhSmLYTQPQ2eDE4XmBEZVsfJagQkLJTUCyenp%2FQbzcZma2coXkk%2F8uwAsOhhWb5niXMQQffjUcM%2Bl%2F%2FWkRWQBAC2N7JsYTrZ4HzaeCcdVzkKzgKsov%2BRhbMq%2BBPgAEAjWu8sz8FVsoAAAAASUVORK5CYII%3D
png;base64,iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8%2F9hAAAABmJLR0QA%2FwD%2FAP%2BgvaeTAAAACXBIWXMAAAsTAAALEwEAmpwYAAAAB3RJTUUH2QEaEik3GHg09gAAAWFJREFUOMudk7FLQlEUxn%2BGbxF8T7BBEHk3J1vyLdqYYEHji8Atsz3IuT%2BgGh1y1ta75OiQEA0OBWGDVBJhQ%2BQi2QtyELLhCWr4XuSBO9zvnPOdj%2FNxwCWkQJMC3a1mAfcoKyoNKdD%2BTSAFmhrDXNohAJjzKDAjJkS2AMjNQ5APrYMvDGqMlNMuvCO5cSAwwgwgEExg%2BMI2EM1C45CCFDQmettAxSMFutdPO5q1UcUP6jJoMVDUcfXHPQw%2Bx%2F%2FmMVgP5D0jBaVQmpxxNN3kFI%2Bn0CrSAFKTW9%2BtbjLs3DLs951fPc9QCkpO1sXPV3jvPrk2Hzi6kGlzN7Aof73Olt638fJfNqYWk7MJgjZuOhJIgR5MYAAMLLjZh%2BoqveczOx9K2wPcFBjBJLxdQG2DXqeGObAQzRPK9aztkKJNE3h%2FE3SvoVXkEshl2ryM8D0JlattCsNvhNv56lKw9seJT%2BV%2FAKTohYjLFZjPAAAAAElFTkSuQmCC
Nokton 50 1.5
Nokton 35 1.2
The complete dressed-up thread, including E-P1 and GF1 combos:
http://www.flickr.com/photos/coyanis/sets/72157622543303143/
Does Olympus make M mount adapters for micro 4/3rds ?
No, but there's a bunch of Leica M mount and Leica Screw mount adapters available from Novoflex, at ebay stores, etc.
For M mount lenses, I use the one from Voigtländer (bought it from cameraquest.com):
For Screw mount lenses, i use an adapter from an ebay store:
Questions about the EP1/EP2 Operations
1) Do you really need the VF for wider lenses on either EP1/EP2? Doesn't the LCD display the full image? What about for the Oly 17 f2.8?
2) What kind of shutter lag do you have for the AF lens? What difference in shutter lag does using MF lenses cause?
If these are answered elsewhere please point it out for me.
jsrockit,
when I look at your 15 mm Heliar set-up picture, I wonder how the cockeyed hood affects the pictures? Can it be set on correctly? (= with largest frontward extensions of the butterfly hood parallel to the camera body bottom)
Do you have to do anything special to meter with these lenses???
I don't have any m43 cam right now, but have had G1 and E-P1. You don't have to do anything. You can set the mode to either P or A, and use camera as Aperture Priority. When you use smaller aperture, the through-sensor preview will gain the brightness/sensitivity to compensate darker view. It's quite usable with EVF (G1 has great EVF). I didn't like using manual lenses with built in LCD though.
Reviews say EP-2's EVF is better than GF-1's, but a bit less detailed compared to G1's.
