The Nikkor-HC 5cm F2 is often overlooked in favor to the Nikkor-SC 5cm F1.4. With the discussion of small RF lenses on Nikon Z-mount lenses, I went back to Rotoloni to read up on the 5cm F2. From the book: the Tokyo marked lenses are made in occupied Japan, even if not marked. The aperture on the Tokyo marked lens does not have click-stops, the Japan lens does. I found a pair of lenses on Ebay with various problems, haze, coating marks, etc- bought the pair for just over $200. 1) to compare the two, and 2) to test the "less than perfect" lenses against my mint/late version. The latter- prices are creeping up from the $150 that I paid for it 15+ years ago.
Both lenses arrived: the NKJ lens required the filter ring to be straightened out, 5 minutes. The NKT lens required haze on each side of the aperture to be cleaned out, 5 minutes.
First up: differences between the two lenses.
1) The coatings were changed, the NKJ is a deeper blue.
2) Construction is different for the rear of the mount. Four screws on the NKT, none visible on the NKJ. Yes, the Tail of Two Nikkors.
3) The rim of the front optical block changed from chrome on the NKT to black on the NKJ.
4) The IR index is between F2.8 and F4 on the NKT, and between F4 and F5.6 on the NKJ. This suggests that the optics are different between the two. Maybe another reason for changing the rim from chrome to black. Black paint used for the "R" on the NKT and red used on the NKJ.
5) Clickless aperture on the NKT, click-stops on the NKJ.
- and a few minor differences, I'll need time for calipers...
