Efke 25 + Rodinal = beautiful tonality
MarkG
11:04 PM
I've been shooting Efke 25 lately and developing it in Rodinal (1+100, 10 minutes, 68 deg F) and I have been very pleased with the results: minimal grain (duh!), wonderful tones, and an exposure range that seems broader than T-Max 100. Attached are a couple of scans from a roll of Efke 25 that I developed recently.
That sounds interesting, I've never tried Efke 25. I have tried Tmax100 with Rodinal 1+100 but semi-stand. It did have great tonal range, but it didn't seem any different than 1+50 so I use that occasionaly. Recently I've been using Tmax100 at 50 in HC-110h and finishing the last three minutes with Borax. Here is one, this is my stock shot for shadow detail:
10 minutes seems a bit short for 1:100, according to the massive devchart.
Couldn't resist posting some of my results with this film. I have only ever tried one roll of KB25 in Rodinal 1:100 for 12 minutes, I think (just followed the massive devchart). I also tried KB50. Both are nice films, and I am going to use them more when my supply of Agfa APX100 is gone. For example,
lens was the Heliar 50mm/f2
I've had wonderful tonality from Adox films (both 25 and 50) in Neofin Blue, but can't seem to get my images posted to show this.
imush - lovely series! I particularly like numbers 3, 9, and 11. Re the time: 10 minutes yields good results but maybe I'm pulling it out of the soup too fast. I'll try it a bit longer next time.
I like your images. Tonality is great indeed. Is it film scan or a print scan and if film, may I ask how do you scan it?
Great shots, folks. I shot a couple of rolls of Adox Pan 25 recently and first impressions were good - I need to get to know it a bit better.
EFKE 25 is one of the best BW films for scanning
Developed in Rod 1+100 for 10 minutes it has no problems with artifacts (grain)
Rollei ATP is also very good
have not tried the 25 yet
While I do agree on the tonality, Efke25 in Rodinal just gave me way more grain than I'm willing to accept at this film speed. In fact, I found the grain to be the about same as PanF in Rodinal, which is a full stop more sensitive...
Efke 25 in Rodinal is my favorite B&W combination. Great blacks! A bit contrasty in direct sunlight, but absolutely superb on a cloudy day or if your subject is in a shadow.
Jim B.
Thanks Ruvy! I scanned the negatives on my KonicaMinolta DimageScan Elite 5400II and then sharpened them in PS.
Kossi - what film did you find with less grain at this speed? Or do you use a lower speed film and if so, which one?
i've only used one roll of my efke 25's so far, i rated it 25 and dev'ed it in diafine (usual 3+3min, 20 degrees). Turned out just a bit too thick...but still very useable/scannable. i guess an e.i. 50 would be better. Here are two frames (6x6!! so don't look for the grain).
Not sure if you were asking me as well, but I use a Nikon Coolscan IV film scanner (an older model that only does 2900dpi).
I've followed the Rodinal 1:100 10' recipe and negatives looked very "thin", after scanning I liked very much the results:
efke KB25 in Ultrafin liquid
I like it in Tetenal Ultrafin Liquid.
Picture taken in Croatia some time around noon.
Uwe
