Electro 35 GT battery help
Pirate
Guitar playing Fotografer
8:24 AM
What batteries are you guys using? I'm picking up my first Yashica Electro 35 GT soon and need batteries.
Also, is there anyone special that works on these- things like just cleaning the inside of the viewfinder?
Thanks for any help!
Have you looked at YashicaGuys web site.
All things Yashica RF. special section on the G series. I think he sells or in detail explains the Yashica G battery situation.
I purchased an adapter from a fellow in Arizona, years ago, that turned out to be the base of a .410 shotgun shell, cut down to the brass base, with the primer punched out... a loose rivet in the primer hole as a contact, and a spring inside. A 6V battery just fit inside the shell and it worked Great. Actually that was for a Lynx E which was different than the G... sorry.
I bought two from him for $10. Haven't seen him for a few years.
Here is a link to the battery adaptor from Yashica Guy. Check it closely to see if its the one for your camera.
http://www.yashica-guy.com/document/battery.html
Another vote for the Yashica Guy. Bought one of his adapters last year for my GSN. Works great. (Though I'm pretty sure a handy person could put together their own adapter without too much trouble). ;)
One CR123A battery + 2xLR44, work great without any adapter.
Instead 2xLR44, you can also use one CR1/3N.
Try not to mix batteries with different chemistry, which may cause overheating and leakage. Use lithium with lithium, alkaline with alkaline.
I've got several Electros. I think the best Electro battery adapter is the one sold on eBay by bennfoto
He has them listed most of the time; the item is available now.
You're right.
In that case best solution is CR123A + CR1/3N, without adapter or 4 x LR44 taped together with small spring to reach contact on battery cover.
Its not a rocket sience and work like a charm.
For 16 bucks currently you can't beat The Yashica Guys professionally done solution. Includes the battery and S&H. So 10 bucks saves a lot of fettling around.
Following up my own, with permission of the seller bennfoto, here is the adapter I like. It's rigid, it's easy to get the battery in and out, works like a champ. He has it listed frequently including now.
