Leica LTM elmar stuck on leica IIIc
DavidC
8:02 PM
I just bought a Leica IIIc with 50mm f3.5 elmar on evilbay and upon receipt tried to unscrew the lens from the body but it appears to be stuck tight.
Any ideas on how to unscrew the lens without causing damage to the lens/camera??
Yes, don't overdo it with the naphtha, it will dissolve the shellac/glue used to hold the curtain straps onto the rollers in the shutter.
Thank you all. Was finally able to pry the lens loose without a drop of lubricant. It is now attached to my M2 via adapter which is much easier to unmount!!
