Mark W
dazed and confused
NONE of the Canonets meters will work accurately with anything but a 1.35V (accept the ones with a Selenium meter cell) battery what you guys are doing is relying on your color neg film to make up for the vartiation in exposure you are getting. Try shooting 100 ASA slide film with your Canonets and 1.55V batteries and you will see what I'm talking about.
Alkalines have a steady voltage drop curve from the time you start using them until they are dead. A Mercury has a steady discharge rate until right before it dies and it dies very quickly. The Silver Oxide cells does the same thing but at a much higher voltage. A light meter is actually a voltmeter the more light hitting the cell the more resisitance to current flow the meter records this causes the reading to raise. If you start out at a higher voltage and then drop down through the proper voltage and end up way below the proper voltage how the heck it the meter supposed to read a thing based on the contsant voltage it is calibrated for..
Saying something works because you can get away with does not mean it works properly. I can dump 30wt motor oil in the Automatic transmission in my car and if the fluid level is correct it will go right down the roa :bang: d BUT it ain't working right.
Same with this screwed up idea that a Cds meter will work on a battery of improper voltage and discharge rate is cheating the new camera owner out of the true ability of the camera.
STOP DOING IT YOU DON"T KNOW WHAT YOU ARE TALKING ABOUT
