Epson 4990 Banding with Color Neg Film
Dave Jenkins
Loose Canon
3:50 AM
I've been using an Epson 4990 for several years to scan medium format and 4x5 transparencies with excellent results. Recently, I thought I would try some color negative film for its greater latitude, so I shot a roll of Kodak Portra 160 in my Rollei. The negatives look fine when viewed with a 10X loupe, but I'm getting what appears to be horizontal banding as well as vertical streaking in the sky areas. I've never seen this in my transparency scans. Any suggestions?
Are you doing any multi-sampling? I had this happen once or twice when I was multi-sampling. Also, vibrations can affect the quality of the scanner - If your laundry machine is going on in the other room and subtly vibrating the desk, it might cause the same issue.
