moodlover
I've scanned thousands of medium format negatives on this, promise that I am "intimately acquainted" with this scanner and it's softwares both Epson Scan and SilverFast (even if the screenshots show otherwise). Epson Scan has forced me to learn what every window and button does but this issue is a total curveball. With a fresh install on a totally different computer and 0 film in the scanner, it gives pure green output. Since you are so much more experienced than me, you should know that this isn't normal, should not be happening, and is not user error. There can't be user error when it gives this output by itself with a fresh reset. There is a reason for the "settings like that". Its because its completely reset. There are no settings that change or affect the pure green preview, not in the configuration window, and certainly not in any of the image adjustment tools. The preview should be pure black but it's not.Hi,
I've been using Epson Scan for around 8 or 9 years (with the 800s predecessor, the V700). So yes, I've scanned with it a bit. By the sound of it, more than you. My point (perhaps I was being too obscure) is that, with settings like that you do not present yourself as a user who is intimately acquainted with the software. I personally suspect there may be some user error involved. Regarding complaining, perhaps I should have been clearer, I was actually referring to their service but I could have expressed that better. Sorry. Of course, you want a fully functional process (is that not self evident to all of us?). I still think you've done pretty well though, because by your own admission, its working OK with Silverfast, but you are still getting a brand new scanner. Personally, I think that's a pretty decent start, even if you may not.
I do have a tip for you that might be useful. Find your temp file (or whatever a mac has that passes for that) and ensure any twain files or temp folders that Epson Scan has created are deleted. Empty your trash can or whatever it's called on a Mac. Uninstall the software. Reboot. Download it from Epson's site and re-install.
I use a PC with Windows but can vouch from years of previous experience with Epson Scan that these leftover folders and files can be the source of various glitches including Eg. failure to preview frames correctly and refusal of scans to process for frames that have digital ICE enabled. No guarantees it will work for a Mac also but it's certainly worth a shot as it's cost neutral. Apologies for not suggesting this in my previous post (my posts are, believe it or not, often helpful) but I only just recalled it. Seriously. It's been a three cup of coffee day for me, today.
Regards
Brett
I never complained about their service, not sure where you got that. Their service was excellent. I am not receiving a brand new scanner. Replacements are all refurbished, and who knows how many problems that one had or how long it will last as well. I am complaining about their hardware, but I guess $800 for a scanner is considered low-end.
Regarding your tip, I switched completely to a computer that never had Epson Scan installed and before I did anything an empty preview shows pure green. It shouldn't, it should show black as you know. Thanks for the tip I'll see if I can give it a go anyway.
Edit: deleted the epson temp files, uninstalled with epson's uninstaller, emptied trash, rebooted, reinstalled, same issue.
